Installing toilets over wood flooring
Discussion in 'Toilet Forum discussions' started by ttw4454, Sep 5, 2006.
  1. ttw4454
    ttw4454 New Member
    Jun 16, 2006
    I'm installing new maple flooring in my house. Are there any special precautions to take for installing toilets over wood flooring? Thanks,
  2. jadnashua
    Is this solid, nail or glue down stuff? Hopefully, it is not an engineered floating floor. I don't think it should be much of any different from putting one anywhere else. If it is a floating floor, I think you are asking for problems - they don't like being anchored down. For ease of cleaning up, I opted to tile under that area when I put down wood floors. I used the same tile as the vanity top which ties it together.
  4. ttw4454
    ttw4454 New Member
    Jun 16, 2006
    Jim, thanks for the quick reply. It will be solid 3/4" flooring that will be nailed down.
  5. Donna Shoemaker
    Donna Shoemaker New Member
    Sep 5, 2006
    installing toilets over wood flooring.
    Here is my one word of advice for a toilet over wood: AIM. :D
    Seriously, I have wood in a powder room, which has turned out to be the most used toilet in the house. The floor color is more oak, so light maple might not be as easy, but I have never had a problem. I take the entire seat assembly off about once every 6 months and completely clean and sanitize, which will help keep any drips from coming off the back seat bolts to the floor over time. Just aim, and keep things clean, and you should not have any problems.
    Good Luck
  6. donmoore1904
    donmoore1904 New Member
    Sep 21, 2006
    Is toilet over engineered floor a no-no?
    I have spent months completely remodeling a bathroom. Moving next to the floor, which is supposed to be a floating floor of the snap and glue stuff. I was going to run it under the toilet edge. I hadn't thought of complications vs stationary floor. I guess this would be a good time to see what I might use for grout in this case around the bottom edge of the toilet (I have used plaster and grout). Anyone done this? Thanks in advance. Don
  7. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    What's the floor surface now?
  8. jadnashua
    Talk to the help line of the flooring manufacturer. They typically don't want anything anchored through the floor. It needs to be able to expand and contract, and anchoring it by something like a toilet can be a problem. I used a floating floor in the bathroom, but used matching tile on the vanity and under the toilet while using the foating floor everwhere else.. It is easier to clean, too.
  9. donmoore1904
    Sep 21, 2006
    The floor surface right now is the uinderlayment that the tile was attached to before it was chipped away. The underlayment is in pretty good shape, and I was going to level the few places that a ply or two came up. HBer is the layout:
    w=wall x=tub deck f=floor t=toilet
    wwwwwwwwwwwwwwwwwwwwwwwww
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxfffffffffffw
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxfffttttfffw
    xxxxxxxxxxxxxTUBxxxxxxxxxxxxxxfffttttfffw
    ffffffffffffffffffffffffffffffffffffffffffffffffffffffw
    I was hoping that since toilet is in a little alcove, the expansion and contraction would not be an issue. The advice to check with the maufacturer is good. I'll give that a shot. Don
  10. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    The reason I asked was the flange should sit on top of the finished floor, so if you're putting 3/4" maple down, you'll probably have to raise the flange.
Similar Threads: Installing toilets
Toilet Forum discussions Installing a toto ultramax II Jan 31, 2017
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions Porcher Veneto: Need help installing Piston Jul 9, 2016
Toilet Forum discussions Plumbing Hacks Video, installing a toilet with Terry Love Jun 28, 2016
Toilet Forum discussions Need help installing 3x4 lead drain pipe on 3" steel pipe Mar 15, 2015
