Installing jacuzzi 6060 whirlpool bath
Discussion in 'Shower & Bathtub Forum & Blog' started by jjrausch, Jun 1, 2008.
  1. jjrausch
    jjrausch New Member
    Jun 1, 2008
    Hi,
    I am in the process of installing a jacuzzi 6060 whirlpool bath. It contained hard foam blocks and the bottom of it and from what I understand it does not have to be installed on a bed of morter. How ever it appears to rock quite a bit on these blocks. Would it be OK to spray in that canned blow in foam to help support it better, or should I drop it in morter?
    TIA
  2. Terry
    Aug 17, 2004
    Some use mortar as a filler, you can lay plastic over the mortar, and that way the two materials do not touch.
    Most of the time, if you set the deck perfectly, and then drop the tub, it's not perfect. To leave a one inch gap between the bottom of the tub, and the floor allows some ridges or piles of mortar that will flatten out to the right level when something is dropped over them.
    If mortar is applies in a full coat, then it's the same as guessing with wood. You want the little bit you put in to be able to squish out and find it's right height.
  4. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    I prefer Structolite to mortar. More user friendly, imho.
Similar Threads: Installing jacuzzi
Shower & Bathtub Forum & Blog Question on installing a Signa Jacuzzi Soaker Tub Jan 17, 2011
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Installing a washer drain 1 ft from main stack - is vent necessary? Jul 17, 2016
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
