Inline Water Pressure Pump
Discussion in 'Irrigation / Sprinkler Forum' started by maverick30900, Apr 6, 2008.
  1. maverick30900
    maverick30900 New Member
    Apr 6, 2008
    I water my lawn via my two outdoor faucets and I would like more pressure so i can run multiple sprinklers off one faucet and a single sprinkler off the other faucet. I am looking to boost pressure from the faucet to run multiple sprinklers. Is there a pump I can connect to this faucet to boost pressure?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The problem is not so much a pressure issue as a volume issue. The hose bibbs you are using are likely fed on 1/2" pipe, which means about 5 to 7 gallons per minute is all you can get. If you try to "suck" more water using a pump, the water velocity in the pipe and the pressure loss within the source piping will increase dramatically.
    The proper course of action is to source the sprinkler system from a point in the water supply system closer to the meter...from a large pipe.
Similar Threads: Inline Water
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum Mainline Repair Still Leaks Sep 27, 2010
Irrigation / Sprinkler Forum Mainline Lateral Pressure Loss Feb 24, 2009
Irrigation / Sprinkler Forum Inline Backflow Preventer - Plumbing Supply in Seattle? Apr 29, 2005
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
