In-Floor heating
Discussion in 'HVAC Heating & Cooling' started by idoc4u, Jan 7, 2010.
  1. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    I am in the process of finishing a basement and am considering not only running duct extensions, but also adding in-floor heating with electrical mats.
    Does anyone have an opinion regarding forced air heat + in-floor heat VS forced air &/or electric baseboard heat?
    I don't know how long it takes for the floor to heat-up using in-floor heat, or if it can be run (obviously in thin-set) under carpet squares.
    The baseboard heat concerns me. Eventhough I have a sump pump with back up, what if the basement takes on water and I have baseboard heat?
    Thanks in advance for opinions.
  2. jadnashua
    On a slab, if you don't have insulation under your slab and it is not dry (especially if there is any water flow), the efficiency of heating the slab will be poor. You can take the chill off, but you may not want to use it as the primary heat source. Putting carpet over top probably won't help. With a large mass, response tends to be slow. If the area floods, I'm not sure I'd want either in-floor electric or electric baseboard. You can get a lot denser heat transfer with hydronics. See what the others think...
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Heating wires are protected by GFI thermostats
    The heating wires are protected by GFI thermostats for the heating cable or matts. I'm not an expert but I believer this is safer than electric baseboard heaters.
    I have looked into many different heating options over the past year and have chossen for my home to install an old school boiler and column radiators.
    I found many wall hung electric fan heaters and electric radiator heaters available. If you are concerned with this install an electric wall hung heater a couple feet of the basement slab.
    Good Luck.
Similar Threads: In-Floor heating
HVAC Heating & Cooling Swapping H/W radiators for in-floor! Apr 8, 2009
HVAC Heating & Cooling Apollo hydro heating Jan 30, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling More CFM for cooling vs. heating? Jul 27, 2016
HVAC Heating & Cooling "Summerizing" a hydronic heating system May 11, 2016
