If I needed to repair my Fleck 7000 SXT, which has a plastic bypass on the valve...
Here
Would I need to remove the bypass or could I keep it on? I have a bypass in the line already but also have the bypass on the valve itself. Theoretically, if I needed to fix the valve, would I have to remove the plastic valve mounted bypass (despite having a bypass on my plumbing already)?
You could keep it on.
Here
So i just take off the bypass, keep it attached to the plumbing, take off the valve, and do what i need to do to fix it?
Here
Haha, thanks fellas. I have the unit and do indeed know how it works, but I am still wondering if I can just leave the bypass on the pipes and take the unit (valve head) off. Theoretically. ;)
ditttohead
Water systems designer, R&D
Ontario California
Yes, if you decide to move and want to take the system with you, you would only need to purchase a new bypass and plumbing connectors.
Theoretically you could remove a pair of orange clips and pull the tank+controller assembly away from the wall. Theoretically is a good word here, because I have not done it. You would not want to tilt. So whether you could pull that off safely might depend on you and your tank size. A smooth floor would seem to help. It might also depend on how much give is in your piping.
A flex connection would seem to be a lot better if your code allows.
Here
Thanks guys! I guess it's redundant to use the bypass on the 7000sxt if i already have a bypass but whatever.
ditttohead
Ontario California
Yes it is redundant. I prefer a high quality 3 valve bypass anytime, but the valve mounted Fleck and Clack bypasses are great quality and can be repaired easily.
