Ideas on how to get a 150# water heater into the attic?
Discussion in 'Water Heater Forum, Tanks' started by ForrestGump, Oct 16, 2008.
  1. ForrestGump
    ForrestGump New Member
    May 1, 2008
    IT Pro
    Friendswood, Tx
    How do you pros go about getting a 50 gal water heater thats weighs 150lbs into a attic?
    I have a staircase inside a 1 story house in the hallway and the water heater is 3 feet from attic opening.
    I thought of getting a come along and hook it to the new water heater and the rafters.
    Would it be ok to take 2 - 3/4 galvanized T's connected to the hot and cold nipples with a large bolt running though the T's so I can hook the come along hook to? Would this damage the tank?
  2. Terry
    Aug 17, 2004
    I use a copper flex connector between the two pipe nipples and just lift it up by hand.
    150 pounds isn't very much weight.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    what I use....
    Generally when I got a really mean water heater
    to install I let my apprentice do the lifting....LOL
    and if it is extra extra mean, then I hire someone from
    manpower for the day....to help the apprentice do the lifting....
  5. ForrestGump
    May 1, 2008
    IT Pro
    Friendswood, Tx
  6. Terry
    Aug 17, 2004
    I'm not going to guarantee that.
    I do it. But then I do lots of things that can't be done too.
    Lot's of times I just use a flex that is going to be tossed anyway.
    I like the fact that there is some give to it, and that it makes a nice handle for my hand.
    If you can have someone below helping a bit, that's even better.
  7. hj
    heater
    Use a rope and make a barrel sling under and around the heater. Then hook the come a long to the sling.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'm sooooooooooo glad we have basements around here...:cool:
  9. Ladiesman271
    Ladiesman271 Homeowner
    Aug 22, 2008
    Care and maintenance of transformers
    Sounds like a perfect time to convert to a tankless water heater!
  10. Cass
    Cass Plumber
    Nov 12, 2005
    I would definitely use HJs sling method when lowering the old heater...
    I would not trust those old nipples to hold...they might but...
    I wouldn't want to be the guy on the bottom if they didn't.
    [​IMG]
  11. ForrestGump
    May 1, 2008
    IT Pro
    Friendswood, Tx
    Thanks everyone for the help. I am going to buy GE 12yr 50gal water heater today at HD and install it on Saturday.
    I will try to make a YouTube video of me getting it into the attic and post the link to it here next week.
  12. hj
    heater
    I'm glad we have VERY few basements, and VERY few heaters in the attic around here. It could end up like a supply house years ago. They had a shaft where they used a hoist to lift items up to the higher levels. A new guy was getting a cast iron bathtub down from the third floor and tied the cable through the wooden slats at the end, instead of through the waste and overflow holes. When the staples pulled out and the tub hit the clay tile pipe and fittings in the basement, it sounded like an atomic bomb had gone off. There wasn't much of the tub's enameled finish left either.
  13. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Water heater in attic
    Now ! !
    Would be a "very good" time to install that new drain pan under that new heater run the 1" pvc across the attic and down the
    outside of the house, ! !
    Before you wake up some morning taking a shower in bed ! !
  14. jadnashua
    If I had a gas WH, I'd probably install a WAGS valve when replacing it...it shuts both the gas and water off if it starts to leak. www.wagsvalve.com No power, it's all mechanical. Uses the same type of actuator that triggers the inflation of safety floatation vests used on airplanes - all it needs is to get wet and a spring and switch does the rest.
  15. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Same here. I would hate to think of putting anything like that above my head.
  16. Terry
    Aug 17, 2004
    Most water heaters around here are in the garage.
    Thank goodness.
  17. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    Just tie it onto the bottom of a helicopter and drop it thru the roof.:)
    ....lol... stoooopid idea eh?
    About as stoooopid an idea as having a hw tank in the attic!!!:eek:
    S
  18. jfarnold
    jfarnold Apprentice Plumber
    Mar 3, 2007
    Apprentice Plumber, primary caregiver to two child
    Metro DC
    I would get a friend or neighbor or two to help me if I didn't feel I could do it myself. I would be afraid of yanking out some structural member through some mishap with your chain and strap. And yes as an apprentice it's me doing it, with a song in my heart.
    It's just like carrying a drunken fat chick up a flight of stairs, it's not moving Cheops.
    If you're replacing 7 year old water heaters, you need to more aggressively insulate it and the pipes to keep the condensation from eating it up again.
    Good luck.
  19. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    :eek:
    Sorry to say I can't relate...
Similar Threads: Ideas 150#
Water Heater Forum, Tanks Expansion tank location ideas Jan 12, 2012
Water Heater Forum, Tanks Ideas for saving energy Apr 13, 2009
