I need this...
jrprusak
Anchorage, Alaska
What is this called and where can I find this? It is a 1" brass or bronze plumbing fitting maybe 5" long with 1" female threads on the ends and has severasl 1/4" threaded taps on it to mount a pressure switch and pressure gauge.. Just a straight manifold, but I cannot find this replacement anyplace...thanks
It may be called a " pressure manifold".
Tank tee is similar, but it is a tee. Perhaps you could plug bigger tee port and use the straight part.
jrprusak
Anchorage, Alaska
Thats kind of the idea, but it is actually only 3" long and has 1/4" and 1/8" threaded taps. It is a type of straight maniflod, but not as big as a pressure tank Tee manifold... I cannot find this anyplace, so it must be called something else
jrprusak
Anchorage, Alaska
It does look like the spring check valve with taps, but it is not a check valve, just a straight thru with taps for pressure switch and gauge..
