I need a timer for a bathroom fan/light/heater combo.
Discussion in 'Electrical Forum discussion & Blog' started by Erico, Jan 22, 2012.
  1. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    The plan is to place the heater on the timer and switch the fan and light.
    I have to check again, but I believe the heater is rated at 1000 watts.
    The largest wattage timer I have run across is 600 watts.
    Can anyone steer me to a supply house who carries higher watt timers? Perhaps my google fu isn't up to snuff.
    Here is what I have found and what I had in mind (only higher watt timer).
    http://www.iaqsource.com/product.php?p=ps_3funswieletim-i&product=172673
  2. jadnashua
  4. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    Thanks for that.
    For some reason, I have the hardest time navigating their site.
    I still can't find the double rocker switch on their site. I know it exists becauuse it's on HD's website here:
    I sure would like to read the specs, Can find it under HD's published MFG model #.
    I assume a regular 15 amp double rocker would do the job of running the fan and light. Not sure what kind of wattage these switches are or what my fan uses.
  5. jadnashua
    A fan is likely less than 200W, probably a lot less. As to the light, most won't hold more than about a 75W bulb.
  6. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    You act like you're running a hair dryer on the timer...
  7. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    Huh?
  8. dlarrivee
    Jun 28, 2009
    Canada
    Some hair dryers are 2000w, does everything you plan to hook up here seriously draw that much power?
  9. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Yes, he said a heater.
  10. dlarrivee
    Jun 28, 2009
    Canada
    Okay, my mistake.
    I was thinking heat-lamp and fan combo.
  11. hj
    You will probably need a rotary spring wound timer to handle that amperage.
  12. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Ever thought about a thermostat?
  13. jadnashua
    The link I pointed him to provides several choices of timers that can handle 1500W and are electronic. Now, they are not a combo switch with a second/third switch for the light and fan, so he would need a multi-gang box. Sometimes, the fan manufacturer sells a combo switch deisgned for their product...since he did not indicate a brand for that, I didn't search for one, but he should. But, many places have their fan/light wired with two switches, so you could get a combo switch for those two functions, and put the heater timer in the other place in the box - or, just make the box bigger.
  14. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    I think you are correct. That's the way we will go. Also, I don't know if there is a nuetral in the switch box and some of those push-buttons require a nuetral.
  15. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    Not sure if I have seen one. I should have posted this for our summer/vacation home that we sometimes rent out. My fear is that someone will leave the heater on for a week.
  16. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    Yes, you did. And thank you.
    It's an old broan fan/light/heater original to the house circa 1971. It does have a proprietary control now.
    I need to add switches so I'm cutting a little drywall anyway and intalling a 3 or 4 gang box.
    I haven't pulled it apart yet so I'm not sure what those things went in to? Would it be a regular 2-gang box?
    At this point, I'm leaning to a mechanical winder timer because it appears some of thos push-button timers require a nuetral and I don't know if there is one in the switch box.
Similar Threads: need timer
Electrical Forum discussion & Blog Need Help Wiring Relay for Bathroom Timers Aug 13, 2013
Electrical Forum discussion & Blog Need help wiring ceiling fan! Wednesday at 6:14 PM
Electrical Forum discussion & Blog Need C wire for new Honeywell RTH8580WF Dec 13, 2016
Electrical Forum discussion & Blog Lost one leg of power need help. Aug 4, 2016
Electrical Forum discussion & Blog I am Moving my Meter Base and Need Some Advice Jun 9, 2016
