bathroom light/fan combo
Discussion in 'Electrical Forum discussion & Blog' started by ElectricalNewb, Aug 14, 2011.
  1. ElectricalNewb
    ElectricalNewb New Member
    Aug 13, 2011
    Ap-po-mat-tox Virginia
    :mad: i have a light fan combo that i'm using to replace a standard light in my bathroom since i have a major moisture problem and the house was built in the 50s. i have my black and white (hot and common) wires coming from the breaker and going directly to the light. I have new 12/3 wire running to the switch from where the light is. i need to know where to send my power from the breaker thru the switch and make it function properly.
  2. jadnashua
    Are you adding a new switch so you can control both of them separately?
    The hot lead would get attached to the white from the 12/3, that white would get jumpered to one terminal of each switch (assuming you are going to use a separate switch for both the fan and light). Then use the black on the other terminal of one switch and the red on the terminal of the other. Back at the fan/light, connect the black to the one where you want the switch with the black on it to control, and the red to the other. You should put some black tape on the white lead at both ends to identify it as being hot.
    Basically, you need to jumper the hot wire to the switch(es), and then through the switch(es) back to the things you want to control.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Why would you be using 12/3?
Similar Threads: bathroom light/fan
Electrical Forum discussion & Blog Wiring question for bathroom light/fan May 26, 2011
Electrical Forum discussion & Blog bathroom light/fan operate separately May 4, 2009
Electrical Forum discussion & Blog Bathroom outlets tripping garage GFCI Nov 15, 2015
Electrical Forum discussion & Blog Renovating Bathroom- Electrical Code Mar 11, 2015
Electrical Forum discussion & Blog Bathroom electrical Mar 3, 2015
