HPS Security Light
Steve33
Beaumont, TX
I have an HPS security light on a 20 amp breaker in the main panel under the meter base. From this panel wiring runs to another panel in my home(about 15 feet) where the AC breaker is located. Each time my aAC kicks on the security light turns off for a few seconds and then comes back on. I have read that the AC load can cause a short drop in voltage and cause the light to go out. I have replaced the bulb so I know that is not the issue. I am pretty sure it is the AC load and voltage drop that is causing the problem. My question is what can I do to correct the problem? Even though it is a momentary outage it does it all during the night each time the AC comes on.
First thing to check is that all of the connections are tight. Depending on the panel and the age and use, the circuit breaker could also be slightly loose and may need to be replaced. Or, there could be some corrosion on the bus.
WorthFlorida
Solutions
Orlando, Florida
Google "wiring diagram for high pressure sodium ballast".
There are four components; lamp, capacitor, ignitor (cap) & ballast. Over time with hundreds of on/off cycles along with temperature extremes, the capacitor starts to age and go out of tolerance. Changing the lamp is obvious the first thing to do, it's easy and low cost. I would change the capacitor next. If you get a number off the existing one you can buy them online, they're a little tough to find locally unless you have a electrical supplier near by that stocks these components and sell to non contractors.
Steve33
Beaumont, TX
Thanks---I inspected the panel and everything is tight and no corrosion. The panel is 5 years old.
Steve33
Beaumont, TX
Thanks I did change the lamp. I will try the capacitor next.
DonL
Houston, TX
Is the AC unit and the Light connected to the same breaker ?
Did it always do this ?
Good Luck.
