Steve33
I have an HPS security light on a 20 amp breaker in the main panel under the meter base. From this panel wiring runs to another panel in my home(about 15 feet) where the AC breaker is located. Each time my aAC kicks on the security light turns off for a few seconds and then comes back on. I have read that the AC load can cause a short drop in voltage and cause the light to go out. I have replaced the bulb so I know that is not the issue. I am pretty sure it is the AC load and voltage drop that is causing the problem. My question is what can I do to correct the problem? Even though it is a momentary outage it does it all during the night each time the AC comes on.
