how to stop water from coming out facet instead of shower head
Discussion in 'Shower & Bathtub Forum & Blog' started by dudefromtampa, Sep 25, 2013.
  1. dudefromtampa
    dudefromtampa New Member
    Mar 21, 2012
    PA
    Was wondering if anyone could recommend to stop the water from coming out of the facet instead of the shower head above. Can't afford a plumber right now and was hoping for a bandaid until I could get this fixed permanently. When I pull the nozzle on top of the facet head in the shower, the water is supposed to be diverted to the shower head which is above the picture. It recently stopped working. I tried everything I could think of.
    THanks much for any assistance.
    Joe
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Replace the spout. What may work as a tempera fix is hold the lever up until the shower head runs then release the lever.
    John
  4. jadnashua
    Spouts are generally attached in one of two ways: screw on, or push-on with a set screw to hold it where you want it. Either one is fairly easy to replace. Other than trying to see a hole in the bottom and then finding the screw slot or hole for an allen wrench, both of them normally come off easily. If they used caulk around the end of the spout, you have to cut through that to loosen it up. If it is screw on, then stick the handle of something like a screwdriver in the spout to give you some leverage and turn it counter-clockwise to remove. If it's a push-on, loosen the screw holding it a few turns, then literally, just pull it off.
    [​IMG]
    [​IMG]
  5. dudefromtampa
    Mar 21, 2012
    PA
    I tried that but it didn't work.
  6. dudefromtampa
    Mar 21, 2012
    PA
    thanks Jim for this. Printed it out and going to try it right now. Will let u know if it worked.
Similar Threads: stop water
Shower & Bathtub Forum & Blog tub drain linkage assembly not stopping water Apr 25, 2011
Shower & Bathtub Forum & Blog Shower stops working after water heater replacement Jul 6, 2009
Shower & Bathtub Forum & Blog Stop the water!! Aug 24, 2007
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
Shower & Bathtub Forum & Blog Question on plunger/stopper inside a tub waste overflow drain Dec 19, 2015
