I am adding zones to the existing water heating system.
From the picture you can see starting from that pointed thread connection, the new addition is on the right side.
From left to right after the male fitting, there are a 45 degree turn, a tee, a 45 degree turn and a tee again. They are located closely.
My question is what's the sequence to join them together?
I am thinking the following sequence:
1. solder the first short straight section with male fitting offline;
2. put above unit in with thread sealant and tight them;
3. solder the first 45 elbow and others online.
does above sequence sound right?
at step 2, how to prevent the heat being transferred to the new soldered join and the thread? use a damp cloth?
thanks,
thanks,
