How to remove compression fitting/nut?
cdog
I'm trying to replace the valve assembly for my toilet supply valve. The valve is connected to 1/2' copper pipe with a compression fitting. I want to remove the valve, and the compression fitting, and the flange at the base of the wall to replace everything.
I've had problems replacing compression fittings in the past, and I'm afraid to remove the valve to find that I can't remove the fitting - then not be able to get the valve to seal again!
How do I get a used compression fitting off a copper pipe?
Thanks,
Cdog
Jimbo
San Diego, CA
The easiest way is if the pipe is long enough to just cut it behind the ring.
There is a ferrule puller tool which easily pulls off the ring.
If you are careful, you can slice the ring diagonally, using a hacksaw blade wrapped in duct tape and held in your hand. Orient the blade to cut on the pull stroke.
Or, just leave the compression ring on, and reuse the nut...my unprofessional opinion.
Any hardware store will carry a sleeve puller.
My favorite, though if the nut and sleeve are on super tight, it won't take them off. Then I pull out the Pasco puller.
index.php
Here a handyman had left the back nut and sleeve on. For sealing he tried tape, but then he wound up breaking the back of the stop off.
index.php
They are lucky it was only a drip and not catastrophic.
