makethatkerdistick
I have a 1968 house with cast iron plumbing. Occasionally, I get a clog at the junction of a bathroom and the washer area. I recently redid the bathroom and currently have the toilet off, giving me access to the waste pipe. The clog problems started when we switched from an old-style toilet to a water saving one (1.2 gpf). It could be as simple as increasing the water flow or flushing twice for no. 2 to push the waste farther down the line.
However....
I need to inspect the pipe to verify what could be causing the clog. I assume that the inside diameter of the walls has grown smaller through buildup or that the slope is not strong enough. There is also the possibility of a broken pipe even though that seems unlikely at this point.
Do you have any good ideas for an affordable drain camera for the motivated DIY? I've seen people build their own with a drain snake and a watertight mini camera. My local tool rental place (Home Depot) has nothing of that sort. The next Home Depot that does is more than an hour away. Given the drive and the price I'd pay for the rental, purchasing something becomes an option for me.
If my pipes need being scraped (if there's a possible bottleneck), I assume there's no way around a professional tool.
However....
