Willhelm
I am replacing a tub and will be adding a new drain. I will have to remove the old brass trap as well as brass drain. I don't know what type of drain assembly to use (PVC,ABS,copper) or how i can connect it to the 1&1/2 brass drain pipe exiting to the left of the picture. Basically, I'll be removing everything in the picture and will be left with the brass drain pipe on the left. So, I have to replace the drain & overflow on the tub and tie into the brass 1&1/2 pipe exiting picture on left (after trap). What's the best way to go about this?? Thanks Bill
