How to check for leaks in Automatic Sprinkler system
Discussion in 'Irrigation / Sprinkler Forum' started by herbolaryo, May 26, 2007.
  1. herbolaryo
    herbolaryo New Member
    May 26, 2007
    San Francisco
    The water bill is high. Had all the toilets and faucets checked and fixed. But still the water bill is high.
    We have an automatic sprinkler system. And there was a construction done before around the house which might possibly hit the sprinkler system.
    Since the yard is divided into several zones by the sprinkler, how will you know if there are leaks in that particular zone?:confused:
    Is there a way aside from digging all the sprinkler tubes underneath?
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Most sprinkler leaks become pretty obvious, because either the pressure drops and some or all of the heads don't come up on a particular zone, or you see standing water where you shouldn't see any.
  4. Kiril
    Kiril New Member
    Jun 19, 2007
    Sacramento, CA
    Or you are overwatering your yard.
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    1) Turn off EVERYTHING and look at your meter. Is it moving?
    If it aint, there is no leak.
    If it is, turn off your irigation at the vacuum breaker and or at your house to narrow down the cause. The valves are generally where irrigation leaks are found. Use some imagination and estimate where the main lines/valves are located. Any extra green spots?
  6. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    A system check by an irrigation company is usually less than 50 bucks. Mention that you want a leak check done using the water meter. You probably can get in and out in an hour and save yourself the cost of the checkup on a water bill. Not to mention thousands of dollars in water damage if something is wrong that you are not seeing.
    Your average residential sprinkler system can cause thousands of dollars in flood damage in a very short amount of time.
    Too many folks have lawn services that don't look for problems associated with too much water, broken lines, and sick plants. They mow as fast as they can, while still making the lawn look nice. Another guy comes and dumps fertilizer on the thing, and if its green no one cares that there is a leak running down the lawn, or undercutting the homes foundation or retaining walls.
    If you have no skills in inspecting the systems in your home, you should pay for that service. Not just irrigation, but heating and air, electrical, plumbing and sewer. A lot of home owners use property managment companies for this, or a handyman service.
Similar Threads: check leaks
Irrigation / Sprinkler Forum Starting design - check my flow/pressure please Oct 2, 2011
Irrigation / Sprinkler Forum Is a check valve sufficient for backflow prevention? Jun 20, 2007
Irrigation / Sprinkler Forum which 'wilkins' check valve should I use? May 18, 2007
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum How to find leaks? May 29, 2011
