How should I prepare copper pipe for a quick connect fitting?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amateurplumber1, Jul 21, 2013.
  1. amateurplumber1
    amateurplumber1 Member
    Mar 10, 2013
    Here
    Any tips? Just make sure it's cut straight?
  2. Terry
    Aug 17, 2004
    I would pick up a tubing cutter for that. That gives a nice straight cut.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Ja, a good one does. A cheap one puts threads on the pipe.
  5. jadnashua
    Those fittings typically seal with o-ring(s). At least on the Sharkbite fittings, they tell you to use their reamer tool to deburr the end. You do not want the end of the pipe to nick or slice the o-ring. http://www.sharkbite.com/product/deburr-gauge-tool/ Personally, I think this is a very good idea for any of the similar tech stuff.
Similar Threads: should prepare
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Valve Stem Leak. Should I be worried? Sep 22, 2016
