Sorry I wasted your time trying to explain what actually caused your problem and how to prevent it from happening again. Since you don’t seem to want to take advice from those of us with experience, then go ahead and get a small Flotec tank. It is not your only option, but since you think it is, there is no reason for us to try to change your mind.
I fully expect you back soon saying, “my water shuts off, then comes back on by itself after a few minutes”. That will be your motor burned up and tripping on overload from all the cycling. Cycling was also the REASON for the broken tank bladders, sediment, water hammer, burned pressure switch, and low pressure in the house.
Now I am confused. Take the time to research and get advice, then don’t use any of it. I wish you the best of luck though!
