How long does it take a leak to dry out in a crawlspace?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bounced, Jan 28, 2008.
  1. bounced
    bounced New Member
    Jan 28, 2008
    Georgia
    Hello,
    Total plumbing ignoramus here, so maybe this is a stupid question.
    Found a leak under the house a few days ago. There's a wet spot in the wood around the toilet drain pipe and about a foot away one of the joists has a wet spot that's about a square foot (there's no direct link of wetness between the two areas, but I'm guessing the water is just running along the subfloor).
    I've replaced the toilet's wax seal; it was definitely old and around the flange felt wet, so I'm thinking this was the source of the leak BUT...
    The toilet hasn't been flushed since Saturday morning, and I can detect no decrease in the size of the wet spots. Shouldn't it be drying out by now, at least a little? I live in Athens GA, so the weather has been running from the 40s to the 60s F, if that makes a difference.
    Now I'm worrying that perhaps the toilet isn't the source of the leak.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    get a fan
    set a fan up in the crawl space
    and get some air moveing....
    that will dramatically have an affect on the spot...
    it could take days or weeks if the spot is large,
    but with some air movement, it will go away fast.
  4. jadnashua
    It's sort of like asking, how high is up? Air movement, temperature, soil conditions, and how long it had been soaking in will all have a factor in how long it can take to dry out.
  5. hj
    leak
    If it has been leaking a long time, then the ground is saturated at that point and evaporation or seepage will not occur until the saturation dries up, which could be hours, days, or weeks depending on how extensive it is and what kind of soil you have there.
Similar Threads: long does
Plumbing Forum, Professional & DIY Advice Where does the cleanout for long trap arm continuing into horizontal drain go? Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Why does the water take so long to warm up? Dec 16, 2010
Plumbing Forum, Professional & DIY Advice How long does it take a 1/2" copper pipe to freeze? Feb 10, 2008
Plumbing Forum, Professional & DIY Advice How long does "galvanic corrosion" take? Nov 28, 2004
Plumbing Forum, Professional & DIY Advice Overflow tube under sink that seems to no longer exist Jan 17, 2017
