Justin in NJ
Hi everyone,
I have found this forum to be a great resource for tackling DIY problems, but I think I am a bit out of my league here.
I live in an 8 year old home and approximately one month ago, noticed a crack on the ceiling below where the master bath lays along with a yellow spot. I tracked the source to our shower, but it isn't clear where the leak is coming from.
There is a wet spot on the wall next to the shower stall that seems to accumulate moisture.
I had our handyman recaulk the entire shower, but this doesn't seem to make a difference. He tried caulking the weep holes at the lip of the shower pan, but the problem still presented itself. Talking to various people, some of recommended closing the weep holes and others say they must remain open. Everything I have read online says to keep these holes open, however the problem did first occur with the holes open.
I have filled the pan and detected no leaks. I have also read about weep holes in the drain in some types of shower that the moisture that builds up behind the walls. I had the homebuilder over the inspect the issue and he told me that this type of prefabricated shower pan has no weep holes in the drain, so didn't think that was the issue.
He seems to think the shower door is the issue and needs replacing. I'm not sure why this is though because there is never any visible water outside the shower during or after a shower.
The wall behind the shower was removed from the adjacent room to check the plumbing for leaks and there didn't appear to be any. One of the pictures I posted is the wet spot behind the wall next to the lip of the shower pan.
I am wondering if it is somehow condensation that doesn't drain properly behind the grout and tile, because
the wet spot on the outside wall seems to appear around 30-60 minutes after taking a decent length hot shower.
Otherwise, I am planning on replacing the shower door as recommended by the home builder, but I am terrified that the problem will just represent itself after all the dry wall is fixed and repainted.
I'm in Central Jersey if anyone can recommend someone knowledgeable to come fix the issue! Thanks!
Appreciate everyone's thoughts on where to go next.
