How Kosher is this?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by philippo, Jan 15, 2013.
  1. philippo
    philippo New Member
    Jan 15, 2013
    Washington
    Okay, here's a "contractor bad dream story", hopefully cut a little bit short.
    It's my own bathroom remodel, contractor raved about his plumber -- his plumber was going to use PEX instead of the original copper that was going to be torn out and somewhat rerouted. Nothing terribly major; move the toilet and hot water heater, plumb to a new bathtub and shower.
    Last weekend we had a major freeze in the Pacific Northwest and I crawled under the house to check on the pipes. Granted, it is a miserable crawlspace -- hard to access and hard to move around in...but I don't think there's any excuse for what I found:
    Aside from the old plumbing parts,torn out insulation, and garbage left under the house, exactly how "standard" is that kind of plumbing layout for PEX?
    I understand it's much easier to use, and flexible, but that doesn't excuse that particular snakes nest!
    Should I insist this be redone? (I think so...)
    philip
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Standard, no. Common, yes. Pex is plastic spaghetti crap.
  4. Terry
    Aug 17, 2004
    It's hard to make PEX runs look nice.
    It should be supported every four feet.
    Copper can get by with six feet.
    It looks like two different insulation wraps. The darker stuff comes preglued, but you have to pull the cellophane off after installation to allow the two sticky sides to bind together.
    The light stuff was tie wrapped.
  5. hj
    A lot of contractors use PEX because they can install it that way, because it takes less time, even it if does use a bit more material. They don't really care how it looks as long as nobody is going to see it.
Similar Threads: Kosher
Plumbing Forum, Professional & DIY Advice Horizontal double wye for two sinks...kosher? Feb 27, 2017
Plumbing Forum, Professional & DIY Advice Is this kosher? Jan 27, 2010
