How do I remove this shower pan/drain in basement?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nilloc, Jun 8, 2014.
  1. nilloc
    nilloc New Member
    Jun 8, 2014
    Michigan
    The house we bought has a shower pan in the basement bathroom, but no surround. I'm planning to install a simple shower surround kit. The current pan is just held in place at the drain (it flexes and I can lift it a bit off the floor, but it stays put at the drain. It looks like the pan and the drain in the floor might be epoxied together. (I'm pretty inexperienced in plumbing if that's not apparent yet, but am fairly handy in other areas.) It looks like somebody previous might have tried to chisel them apart because the drain pipe in the floor is chipped near the top. How should I go about separating the drain pipe from the pan drain?
    Thanks in advance for your help.
    Collin
  2. hj
    The pipe is cast iron, so drill the "caulking" between the pipe and the pan, or break the pan then remove the drain fitting.
  4. Terry
    Aug 17, 2004
    What hj says.
    A sawzall works well for me to cut around the drain and get a bit more access. There is normally a boxed out hole in the slab that you will need to get into.
    Drill bits, sawzll, hammers, cutters,..........just some of the tools.
  5. nilloc
    nilloc New Member
    Jun 8, 2014
    Michigan
    Great. Thanks to both of you. I'll give it a shot.
Similar Threads: remove shower
Plumbing Forum, Professional & DIY Advice How to remove early 2000s Moen Shower Handle Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Hi I have an older Moen shower handle I need to remove. Oct 23, 2016
Plumbing Forum, Professional & DIY Advice How to Remove Kohler Shower Valve Handle Sep 29, 2016
Plumbing Forum, Professional & DIY Advice Trying to remove the Faceplate on a Kohler Shower Faucet. Tried Everything. Help! Jul 18, 2016
