How do I install a toilet to this?... Lead bend no flange
wang168
New Jersey
Replacing an old toilet, to to find there's no normal flange. The previous owner just attached it with a bolt as shown in pictures. I mean there was no leaks or anything. How do I attach my new toilet to this? . It's a cement floor. https://imgur.com/QNR5Gjs
Widgit Maker
Alexandria, Virginia
You put another brass toilet bolt on the other side, just like the one you have, put in a wax ring and set the toilet.
Montreal, Canada
The opening is there as indicated in #2, just flake off any rust and debris with a chisel and it will show.
If there really is no opening for you to insert the flange bolt, then use anything to open it up, dremel or grinder.
wang168
New Jersey
I have no problem inserting the flange bolt just that the bolt would have to sit in the middle of the openings (shown in pic) to mount the toilet I'm these. I guess I could hold the bolt in place with a nut first , then mount the toilet.
wang168
New Jersey
Where the bolt is, is immaterial as long as the head is underneath. It CANNOT "slip out", but use a second nut and washer to hold it in place anyway.
