DirtyJerz
Any ideas? Do I give up and pay $150 for a plumber to screw on a nut for me? lol
Thanks, since it’s Amazon I ordered it. Same problem. The threads are similar but the “outer” connection is a compression one rather than a slip nut.Have you tried threading on a 1-1/2" FIP fitting to see if it would mate properly? If the threads are tapered and for some reason a slip joint nut won't work on them, then the solution may be a fitting like this:
But I'm guessing a bit here, I'm not really clear on how the female threads and male threads on that product actually differ.
Cheers, Wayne
I don't follow your description.Thanks, since I ordered it. Same problem. The threads are similar but the “outer” connection is a compression one rather than a slip nut.
Correct, both have the same behavior as what I get with the SJ nuts I got from Home Depot. Locks on for about two turns and that’s it.I don't follow your description.
Are you saying that (a) the SJ nut on that product does not freely tighten down all the way on the threads coming out of the wall and that (b) the female threads on the adapter also don't seem to mate properly with the threads coming out of the wall?
If so, I'm stumped.
Cheers, Wayne
Got a thread gauge. 11.5 seems right (also wow, inches are crazy enough, but the standard threads are 11 and a half?)
Next step is to take a small flathead screwdriver and clean the threads I guess?
