How do I bolt down a new sink?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rleroux, Nov 16, 2008.
  1. rleroux
    rleroux New Member
    Oct 8, 2008
    I have purchased an 30 inch American Classics Euro Vanity Combination from HD. The cabinet and the sink come in one box. The sink is “cultured marbleâ€. Everything is in place and appears properly plumbed. We began using it last night and everything works fine.
    The issue is the sink seems to just sit in the vanity cabinet. Gravity and pipes are the only thing holding the sink in place. I had expected to find a system to bolt it down similar to what I have seen with stainless steel sinks I have attached to counter tops in the past. But there doesn't seem to be any clips, clamps, etc. If I push on the sides of the sink now, I can move it around a bit.
    Is there a way to hold this sink in place? Perhaps I should caulk it down…?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Yes, perhaps you should.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would run a bead of RTV Silicone around the top of the vanity where it contacts the sink. Use denatured alcohol to clean the excess away. Let it sit for 24 hours without movement to set up.
  5. rleroux
    rleroux New Member
    Oct 8, 2008
    Thanks Gary and Redwood. I'll take the coulking route then.
Similar Threads: bolt down
Plumbing Forum, Professional & DIY Advice what are these called? 1958 amer std toilet hold down bolt caps May 28, 2014
Plumbing Forum, Professional & DIY Advice HELP! Toilet bolt fell down Waste Pipe Dec 28, 2010
Plumbing Forum, Professional & DIY Advice How to fix broken bolts from the sewage basin lid? Do i need a new basin? Jan 21, 2017
Plumbing Forum, Professional & DIY Advice How to remove stubborn tank bolt? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Rusting tank bolts on toilet Aug 30, 2014
