Michael Doran
I purchased a HOMEDEC shower system for $700 and I hate to say this about anyone but the plumber on my addition project was actually angry and very unprofessional and refused to install it. He couldn't even give me a rational reason other than "I did one of those years ago and it was junk." I understand there are different qualities of products out there and that some people like to work with products they are used to but this was over the top. The product has many great reviews and very few negative (only really the nipple length that comes with it but they sent 1" 7/8 and 2" nipples and I can get these locally no problem in many lengths), seems good quality brass, etc and is over $2000 less than equivalent Kohler/Delta systems. I purchased this at the beginning of my project and cannot return it so I am resolved to using it moving forward understanding that if it does have a problem down the road I can cut out the drywall on the back of the shower and fix/replace if need be. Another plumber offered to install it for $2500 and I declined out of self respect and decided to give it a go on my own.
I have now installed the unit myself and understand that the depth of the drop ear elbows is critical and I believe I have them set accordingly. I have a couple questions for you veterans out there and I'm looking for guidance and positive input.
1. When I put the drywall back on how big a hole should I put in the drywall for the drop ear elbow/nipple connections? Just big enough for the nipple or can I go a tad bigger but smaller than the covers?
2. What kind of whole should I cut in the drywall for the valve? Should I try to cut out 4 circles or just a tight square?
3. I know the depth of the drop ear elbows is close but there is no way I can be exact only knowing the thickness of the tile. Can I safely assume that I can either cut or purchase a nipple to get precise after the fact? Or add another rubber insert?
4. I have put temporary nipples on the jets, etc. to pressure test and will leave the water on over night. I don't have any other way to air test it. Is this sufficient or is there any other methods you would recommend without having to purchase a bunch of stuff?
Attached are some pictures and any and all positive input to help this be a successful project would be greatly appreciated!
Thank you,
-Mick
Thank you,
-Mick
