lamboworld
I have a 3200 sq ft home that is only occupied by my wife an I. Our water is supplied by a community well and we pay about $38 per month. We plan to stay in this home for at least 10 more years.
The previous owner had a well installed for an irrigation system and to supply water to a apartment over a garage. It is not currently being used.
I would like to connect the well to my home but I am unsure about how much this should cost.
Here are the specs on my well.
260 ft deep
Well was dug in 2005
1 1/2 HP Flint and Walling Pump
10 GPM
20 Gallon Flotec pressure tank
Square D Pressure switch 40/60 psi
Can someone help me with these questions?
1. Is this pressure tank too small. I think that it probably is. The pressure tank is currently located outside beside the pump in an enclosed small insulated building. I will either need to build a bigger location for the tank or relocate it into my garage.
2. Do I need black flow preventer since I have an irrigation system?
3. I live in central NC. How deep does the water line need to be buried?
4. What type of pipe should be used to run from my well to my home? Copper, Galvenized, PVC, PEX or something else.
5. I have an encapsulated crawlspace. Should the pipe enter the house through the foundation and then lay on the ground or be held from the joists.
6. Is it possible to connect to the existing connection without plugging it. I would like to use a valve to switch between my well water and the community well if I decided to buy water from the city again.
7. Do most municipalities require a permit to connect a water supply from well?
Am I missing anything?
I am pretty handy and plan on doing the work myself but I just need some help before I attempt this.
Thanks for you help.
260 ft deep
10 GPM
