Help with recessed flange.
Discussion in 'Toilet Forum discussions' started by SugarHollow, Jan 22, 2010.
  1. SugarHollow
    SugarHollow New Member
    Jan 19, 2010
    Virginia
    I am replacing a toilet that is a piece of junk with a TOTO Drake. After I removed the toilet, I discovered the top of the flange is about 3/8 inch below surface of the tile floor. Furthermore, the edge of the tile cutout overhangs the some parts of the flange rim, so I do not have unfettered access to the flange. The original installation used a single wax ring with funnel, and to my knowledge it never leaked. What do you all recommend I do here? By the way, the top surface of the anchor screws in the flange appear rusted. Should I replace these? Is it normal for them to rust? This toilet was installed by the builder when this house was built in 1997.
    UPDATE: Well, my new TOTO Drake (elongated bowl w/ Sanigloss) has been in for about three weeks, and so far, no problems. I'm shocked - my first toilet installation and I didn't screw it up - a miracle. This is a great toilet - I am so happy to be rid of that Mansfield 160 (hope I can name names here). I went with the single extra thick (No Seep 10) wax ring - haven't seen any water on the floor, so I guess I did OK. While the toilet base is near perfectly level, I could not get the tank to true level and get contact on all three points. I don't know how important that is, but the toilet is doing its job. Thanks for all who offered advice and guidance - it was much appreciated.
  2. jc60618
    jc60618 DIY Junior Member
    Dec 12, 2009
    Apprentice Plumber
    Chicago
    Get a closet flange extesion kit from home depot. One extesion ring will probably get you flush with the tile. Go ahead ad replace the rusted screws with stainless steel or galvanized screws. Finally when your ready to set the toilet use a wax ring with out the funnel. The funnel will reduce the opening and created clogs.
  4. Terry
    Aug 17, 2004
    Or, put a regular wax down first, and then a wax with horn on top of that, and then drop the bowl down.
    Been doing that for 35 years.
    Installing a Drake
    [​IMG]
    Install kit for toilets
    Notice that the bag of bolts includes four nuts and four washers.
  5. hj
    Or use a #10 wax ring which is probably thick enough by itself. I am not a fan of "extension rings" or spacers.
  6. SugarHollow
    Jan 19, 2010
    Virginia
    Thanks for your help. I considered a flange extension but I didn't think I could do it without somehow clearing the tile completely from the rim of the existing flange. If I'm right about that then I have to figure out how to remove the tile overhanging the flange.
  7. SugarHollow
    Jan 19, 2010
    Virginia
    Just so I'm clear, are you suggesting I put wax rings down on the flange then set the toilet down on the wax rings, or put the rings on the horn of the toilet then put the toilet on the flange? I'm guessing the latter so the ring with the funnel will be closest to the flange (bottom). In the kit you pictured in your reply, are the extra nuts and washers used to tighten the bolts to the flange before I put down the toilet? Also, do you recommend I replace the flange screws? Is there a gasket or some kind of seal below the flange? Thanks so much for giving your time to this website, this is a fantastic resource.
  8. Terry
    Aug 17, 2004
    Plumbers always replace the bolts first.
    Then they put the wax on the flange, not on the bowl.
    I can't tell you how many times I've pulled a bowl that a handyman set, and the wax wax covering the hole.
    Drop the regular wax on the flange, then put the wax with the flange on top of that.
    Or you can do like hj mentions and use one #10 wax.
    I like to sell both rings, that way, depending on the home, you can use one wax or two.
    Either way, they will be able to do it.
    I have not had good luck with the white plastic extensions.
    I've had much better luck with an extra wax ring.
  9. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    What is the deal with the 4 nuts and 4 washers?
  10. Terry
    Aug 17, 2004
    This is how plumbers work.
    They do it right the first time.
    They don't sell them that way at home centers.
    It's all about pennies there.
    For plumbers, it's all about doing it once.
    The first washer and nut secures the bolt to the flange.
    And the second washer and nut secures the bowl to the floor.
    A plumbers time is worth more, so anything that speeds him up is like gold.
  11. hj
    If you use a spacer or extension, you need longer bolts, and definitely need the extra nuts and washers to secure the spacer to the flange, after you apply a sealant between them.
  12. dlarrivee
    Jun 28, 2009
    Canada
    Wow...
    What did I do to deserve a response like that?
    It's just an extra pair of washers and nuts, if you can't find those at a "home center", you're pretty lost to begin with aren't you?
  13. Terry
    Aug 17, 2004
    What response?
    Have you ever been on a job site and asked a journeyman why he and generations of plumbers were doing something that way?
    That's the kind of answer you get.
    To the point, and with a reason, If you're lucky.
    At the home center, what size washer and what thread would a homeowner pick up?
    And on what Isle.
    Or would he buy two packs, and rob one?
    My customers get the "plumbers pack", with four nuts and washers.
    And real stainless braided, not the light weight stuff of unknown material.
  14. SugarHollow
    Jan 19, 2010
    Virginia
    OK, Terry, I hope you don't mind me dragging out discussion of this simple job further, but I want to understand the rationale behind what I see and do. First, if you look at the picture of my flange and drain, you can see that the plumbers who installed it did some cutting around the lining of the cavity through which the waste passes- why is that? Shouldn't a flange and pipe cavity line up exactly w/o any need to cut material away? Would the cutting done there compromise the waterproof seal between the flange and the attached pipe? Do I need to apply some waterproofing to the cut edge? I removed one of the original flange screws and found that it was not just rusted at the top, but all the way down to near the tip of the threads. Is this normal after 16 years of operation, or does this reflect moisture leaking where it shouldn't? When I replace the flange screws, should I use the same size screw or go with longer or wider ones to insure they "grab" well (can you see I'm a complete novice?).
    I was hesitant about using two wax rings, but if you're OK with that, then so am I. But I want to understand why the rings are placed in the order you recommend. So the wax ring w/o funnel goes down on the flange first, then the ring with funnel on top of the first ring. At first I would have thought to use the reverse order, but now this seems to make sense because the funnel on the upper ring should tend to prevent the ring below it from expanding into the drain cavity when the toilet is set on top and the rings are compressed. I also wondered if it might be that you get a better seal/connection between the rings by matching the flat, bottom side of the funnel ring with the flat spacer ring. Anyway, I am curious to know the rationale for the ring order.
    Finally, I was going to replace my gray plastic inlet line with a white vinyl line made by AquaFlo. You emphasized the braided stainless steel above. I liked the white color but if the vinyl is not durable, I can live without it. What are your thoughts on the vinyl vs. the braided stainless steel?
    Many thanks! My Drake arrived today, time to get to work.
  15. jadnashua
    Another possibility is to utilize a waxless seal. Two companies that I know of make them: Fluidmaster and Fernco. If the inside of the pipe is or can be made clean, they should work. I've used the Fluidmaster version (sold at HD and plumbing supply). I've not seen the Fernco version except at plumbing supply houses, but your results may differ. It costs more, but a side benefit is it is reusable so you could remove the toilet say to paint behind it without having to clean off and then replace with a new wax ring. Handy when remodeling when you need the toilet to work overnight.
  16. Terry
    Aug 17, 2004
    I've used the Fluidmaster Waxless with the Drake and other toilets.
    If you use one, push it onto the horn of the bowl, and then install the bowl.
    If using two wax rings, then yes, the horn on top prevents the wax from squishing into the center.
    It's how I was taught to do it 36 years ago.
    Most plumbers don't like vinyl hoses.
    We've seen too many burst.
    They do look nice though.
  17. emd36
    emd36 DIY in AZ
    Jan 16, 2010
    Arizona
    Well, I don't have that much toilet removal experience, but almost every one I've removed had rusted bolts with no noticeable leakage at the seal. I've always used the "extra thick" wax rings and put them on the flange, even handymen can read instructions on the box! Double nuts and washers don't come in the kits but I have used them whenever I had the extra nut, makes the positioning easier without floppy bolts although a bit of wax will hold them for a direct "descent" placement. I have had to cut off a rusted metal flange and replace it. Can't remember all the details of that one but it worked out OK although I also removed the floor tile so didn't have the overhang issue. I thought this experience might be typical, i.e. rusted bolts, rusted flanges, non-stainless bolts, etc.?
Similar Threads: Help recessed
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Yesterday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Help: Trickle sound and smell from Cimarron Jan 21, 2017
