Thanks!1- Putty yes. This seals the water in the bowl from going past the stopper.
2- Nothing. Those threads don't seal anything
3- I often use silicone on these threads to make up for the rubber gasket not doing its job. I smear a tiny bit where the rubber gasket will eventually rest but not below the rubber gasket where the silicone will lock up the nut. It shouldn't be necessary if the rubber is quality.
4- shouldn't need anything if the rubber and the sink match up well.
5- Teflon tape or work in some plumbers putty into the threads. It depends on how visible that joint is going to be. I can wipe off the excess putty easier than cutting the showing tape.
Not a pro. But just realized yours is the same as mine which I recently made a post about. I had to put pipe dope at 5 because Teflon tape wasn't enough. The threads at 3 I was still having some leaking. Not sure what to put there since the leaking isn't between the rubber and sink.
Pipe dope is compatible with the rubber?Below is a picture that I found.
1. Under the flange, putty or Silicone. I use putty.
3. Pipe dope on the threads there, yes I do that. I have also used putty on the threads.
5. On the tail piece, I've used tape, putty and dope.
