Help watering rc track :)
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by justin_92_92, Aug 8, 2011.
  1. justin_92_92
    justin_92_92 New Member
    Sep 18, 2007
    Hello,
    I have a Remote controlled Car race track that i need to provide water for. I really just want to run a few sprinklers at a time and maybe zone them and rotate to cover the track. Im having trouble getting this accomplished and need some help.
    Water source- 300 ft away (brooke)
    Current Pumps- I have two 1/2hp jet pumps available already but willing to purchase something different if needed.
    Currently running a 1-1/4 water line from brooke to the pump 300ft away with a foot valve on end. Not enough pressure to run one sprinkler.
    I also run the pump off a generator as we have no electricity there.
    If running both pumps will work, i will do that. If getting a bigger better pump is my answer I will go that route...but trying to keep cost down if I can.
    Thanks for any help you may be!
    Justin
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you have a large enough suction line and the 300' of pipe doesn't go uphill, a 1/2 HP jet pump should run about 3 sprinklers. If your pipe goes uphill, you may need a larger pump.
  4. justin_92_92
    Sep 18, 2007
    From the water source to the track is probably less than 10' rise. Mostly all long the same level.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Where is this 300 feet of pipe, before or after the pump? If before, sucking from 300 feet away is a bad idea.
  6. justin_92_92
    Sep 18, 2007
    Yeah the way I have it set right now it goes:
    Water-footvalve-300' of 1-1/4 line-pump-garden hose to sprinkler.
    I was thinking about adding a second pump, which i found out was a pool pump :( Is a pool pump going to do any good?
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Move the pump closer to the water.
  8. justin_92_92
    Sep 18, 2007
    Ok, The main reason i didnt was I was thinking a pump (shallow well 1/2 hp) would pull better than it pushes, But wasnt sure.
  9. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    It pushes better than it pulls.
  10. justin_92_92
    Sep 18, 2007
    wow...way better...my foot valve was stuck open too due to sand getting in it. What a difference pushing makes!
Similar Threads: Help watering
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Cistern Help 2 Feb 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Help with well issues Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Need help ID'ing the well/casing Please! Jan 27, 2017
