Help to improve water pump performance
Tiago Dores
Portugal
Hello everyone!
I need you help to improve my setup.
I have an Honda WB30XT water pump for 3" hoses but due to my activity and use I have a weird setup and I'm afraid this is reducing the performance of the pump.
On the inlet side I'm using a 3" suction hose with a 2" anti leaking valve and 2" storz couplings to the pump
On the outlet side I'm using a 3" to 2" adapter with storz couplings to a 55mm hose.
I'm using it with arround 1 meter suction head and 0 total head.
Does this setup affectes the performance? is there anything I can do to improve my performance?
Thank you in advance from Portugal
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
That is a 290 GPM pump. I doubt that you can suck 290 GPM though a 2" check valve. I would use a 4" foot valve and a 4" suction hose attached to a 3" nipple that is 12" long going straight into the pump. Then a 3" hose on the discharge side. You just can't pump much water through a 2" hose, and the suction side is affected even more by restrictions.
Boycedrilling
Royal City, WA
You probably aren't getting much more water than if you had a 2" pump. Most the 2" gas pumps I have will do about 100 gpm thru 2" hose. Most gas pumps will only pump about 35-40 psi maximum.
Tiago Dores
Portugal
Well you just pointed some very important issues! Thank you so much for your help! I'll change it as you said and bost my underwater work significantly.
Thank you both!
Have a good day!
