Help identifying Kinetico components and finding proper resin
Wayne Bailey
Virginia
Hello,
I inherited a water softening system consisting of 4 pressure tanks and salt tank. Well water supply with significant iron content.
First tank in the series comes from the well pump and is marked RT-940-8 PI27305 there is an inner tube type pressure fitting on the head. Output of this tank goes to the pressure accumulator tank. From the pressure accumulator it goes to the second pressure tank with electric timer on the top and is marked RT-10548 PI43521. Following this tank is a dual set of tanks with a mechanical (water flow?) timer. These dual tanks are marked 877203.
The system is 15-17 years old. The media/resin has never been replaced. I am experiencing a significant dynamic pressure drop across the first tank during higher flow rates. My understanding is the first tank is an iron oxidizer tank.
I would like to find manuals and a recommendation for the media/resin for this system. I intend to do a complete service and resin replacement. Kinetico was NO HELP. What a miserable experience with the manufacturer - they referred me to the "dealer" who was even less help.
Thanks in advance.
Regards,
Wayne Bailey
Akpsdvan
Alaska
Photo of the set up?
There might be some manuals on the first 2 units if they are not Kinetico.
Wayne Bailey
Virginia
What a pain in the butt trying to attach image to this reply, so here is the URL:
First tank in the series with ID numbers:
RT-940-8 PI27305
Second tank in the system with numbers
RT-10548 PI43521
and the final pair of tanks with numbers
877203
Thanks for your help.
Regards,
Wayne
Akpsdvan
Alaska
First one sounds like a 9X40 tank and the other one a 10X54 tank.
Part of the challenge is that different companies call the same item different numbers .........arg........ but life moves on.
Any idea what the raw or untreated water has tested out at?
Knowing what the water test is can help in finding out what media was most likely used.
