Hi all, new member here. Temperatures have been at records low lately, -12 the other night! I've been checking my pipes and all is well in the house, but my barn has a room with the well pump and well pressure tank stored there. There is a wall between the pump room, and another room that has the pressure tank. I replaced the pressure tank that came with the house about 6 months ago, there was a bladderless tank there that was water logged, i replaced it with a 30 gallon Water Worker (bladder).
Anyways, please see the attached photos...
I had the pump circuit breaker off, but i forgot to drain the water from the pressure tank before it got freezing cold overnight. The bursted pipe is between the pump/pressure gauge, and the pressure tank. It's about a 3 foot section that is cracked the whole way, but thats it. All the pvc on the Pressure tank side is not broken and should be fine.
SO WHAT SHOULD I DO? Currently it is still frozen solid. I assume i need to cut away that broken section of pipe and replace it.
Question #1: If the ice in the pipe melts towards the end of the week, will the pressure tank empty itself into my pump room due to this broken pipe? I would imagine this burst pipe equates to having a faucet turned ON outside.
Question #2: Is there a way to keep the water in the tank from emptying out while working on this?
Thank you in advance for any support! Trying to avoid a mess and get this sorted asap.
PUMP ROOM
CRACKED PIPE IN PUMP ROOM - 3/4 FOOT PIPE RUNS INTO THE WALL - PRESSURE TANK IS ON THE OTHER SIDE
ON OPPOSITE SIDE OF WALL - THE PRESSURE TANK SETUP
PUMP ROOM
