Heat Tape
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by asayers, Jan 2, 2006.
  1. asayers
    asayers New Member
    Jan 2, 2006
    I have a shower set up that is going to be mounted on an outside wall. I have no options to put it anywhere else. Can I heat tape the lines within the walls?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    No. Dangerous, can cause a fire and the tapes will not last long enough to call permanent. Build a false partition and have access to the pipes.
  4. asayers
    asayers New Member
    Jan 2, 2006
    I don't have any room to build a false wall, nor are there any options move the plumbing. I could re-direct part of a forced air heat duct into the wall. I would have to limit the amount of insulation in the wall in order for it to do any good though and that scares me.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Heat tape in an enclosed wall would be a NO NO. Why can't it be mounted on another wall?
  6. asayers
    asayers New Member
    Jan 2, 2006
    It is a very very small bathroom with no other wall as a possibility.
  7. jadnashua
    I'm not a pro...but if I was hit with this problem, I'd make sure that the pipes were as close to the inside wall as possible, and then I'd consider using a foam in place insulation - it doesn't leave voids and has a much better R factor than fiberglass. This could be problematic if you needed to repair the valve and it might mask a leak. This may mean that your choices of a shower valve may be limited, since many of them are fairly deep. I know that Grohe makes a surface mount tub/shower valve assembly, don't know if they or others make a surface mounted shower only assembly. If you go this route, then all of the guts are outside of the wall, only the pipe is inside (and you should be able to get it closer to the inside wall. You may not like the looks of this. I did it on my shower because there is a pocket door behind it, and I didn't want any interference possibilities, plus, the granite I put up I wanted to stay for a long time nonwithstanding the valve.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    What is above the bathroom, 2nd floor or attic, and when you are standing in the shower can you touch the shower ceiling?
  9. hj
    ceiling?
    Why? Are you suggesting that he mount the shower valve in the ceiling? That would definitely be an unusual location for it.
  10. asayers
    asayers New Member
    Jan 2, 2006
    yes. It is on the second story, a dormer with the attic space above.
  11. PEW
    PEW DIY Senior Member
    You do not say where you are located, but I would agree with Jim. If you keep the insulation between the outside wall and the pipes, and you keep the house heated, you should have no problems. NO heat tape!
    Paul
  12. Terry
    Aug 17, 2004
    I would keep the heat duct away from the pipe.
    Once the heat is off, there is nothing to protect the pipe.
Similar Threads: Heat Tape
Plumbing Forum, Professional & DIY Advice Freezing problem - Heat tape on PEX & CPVC pipe? Dec 12, 2016
Plumbing Forum, Professional & DIY Advice heat tape Mar 6, 2014
Plumbing Forum, Professional & DIY Advice PEX and heat tape Dec 8, 2008
Plumbing Forum, Professional & DIY Advice Heat tape required for house? Oct 15, 2007
Plumbing Forum, Professional & DIY Advice Pipe Heat Tape Too Long Nov 2, 2005
