hairline toilet cracket
Discussion in 'Toilet Forum discussions' started by mlnave, Dec 3, 2005.
  1. mlnave
    mlnave New Member
    Dec 3, 2005
    My plumber found a hairline crack around the inside of my 6-year-old toilet bowl. He declared it too dangerous, saying it might break up under my weight
    (which is a normal weight, by the way). Should I replace it immediately, as he suggests, or is he being an alarmist without reason? Thank you.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Not knowing where the crack is it is or where it starts and ends or how long it is makes it hard to say. Have you used this plumber in the past?
  4. jimbo
    jimbo Plumber
    Was he looking for the source of a leak? Hairline cracks do happen in porcelain. It is usually a manufacturing defect. If there really is a crack ( if he can see it you should be able to see it) and it has developed since the toilet is new, it may be the result of an impact of some type.
    It may have been there forever, and it may be OK forever. But if you can actually see a crack ( as opposed to a scratch) then in the interest of utmost safety , I would probably replace it. A catastrophic failure of a toilet ( bowl or tank) , with or without someone sitting on it at the time, is a big problem. So , while this would be rare, I might err on the side of caution. If you are suspicious of the plumber, just send him away and have someone else come in and do the new toilet.
  5. Terry
    Aug 17, 2004
    If the toilet has cracks, it should be replaced.
    Cracks only get bigger, and could fail at any time.
    Broken porcelain is very sharp, I can show you my 3" cut with stiches on my right arm from getting too close to a broken toilet.
    If the bowl is leaking below onto the floor, it could be causing damage there too.
Similar Threads: hairline toilet
Toilet Forum discussions Hairline crazing on toilet glaze - is it serious? Mar 2, 2014
Toilet Forum discussions Toasted tank seal 110 year old toilet. Hairline crack = cannot replace seal. Feb 17, 2013
Toilet Forum discussions 3 New Toilets have Hairline Cracks at the Bottom Mar 17, 2012
Toilet Forum discussions hairline cracks on old toilet Nov 19, 2004
Toilet Forum discussions Hairline (almost invisible) crack in Toto bowl Jul 20, 2005
