Erik Gronning
Well after months of anticipation our project is nearing completion and the Toto Aquia wall hung toilet was finally mounted. A Geberit Wall-hung Washdown (with 3.5 in.minimum depth) was used as the tank. Upon my first test flush I noticed that a gurgling sound was coming from the tub drain. It sounds like the air is being sucked through the water trap. I tried it with both flows and while expectedly the .9 GPF flush created less gurgling it is still present. Does anyone have any advice? The Aquia does have a mighty flush so possibly it is the sudden large flow of water and ensuing suction that is making the noise but I understood that if the waste pipe was vented properly and a water trap was present on the tub drain a noise such as this should not occur. I deeply appreciate any advice you can provide.
