grohe pop up drain question
dustpol
I just installed a grohe seaberry faucet and a pop up drain. I am having a difficult time with it. The drain itself seems very loose and keeps leaning forward. It does work but I am wondering if I am missing something. The instructions that came with the drain were very brief. I have contacted Grohe and they say that the drains are front heavy. Has anyone run into this?
If you grab it, can you pull it out? If so, you need to be more careful when you insert the rod so it catches the hole at the bottom. Other than that, that's the way it is. It only needs to come up about 1/4-3/8" to drain. If yours comes up further, adjust the position of the attachment to the rod so it doesn't move as much - that will limit how far it can "fall over".
dustpol
thanks alot..I will give that a try. I appreciate the speedy response.
