Goulds J5S squealing
dougq
British Columbia
Hi: I have had this pump on my workbench for a couple of years and wish to make it operational.
It would squeal after running for a while. I started to take it apart thinking the bearings needed replacing.
I noted the impeller has been rubbing on the guide vane, which is distorted. Is it possible that is the squealing?
I could run it on the bench, but I am not sure that would produce accurate results.
When I spin the motor shaft by hand I can not tell if the bearings are shot, I am used to hearing a rumble from
automotive bearings if they are bad.
Any thoughts?
DougQ
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
A bad bearing is what lets the impeller drag the hub. Remove the impeller and run the motor to see if the bearings make any noise. But bearings are nearly always the problem as they are not grease-able and only have so many hours of life.
dougq
British Columbia
valveman, you were quite right, I could hear a bit of a scraping sound when I ran the motor. I took it apart and sure enough the pump side bearing is shot, I will of course replace both. I have a local supplier for the bearings, but I am not sure the best site online to order the pump seals, any recommendations? The impeller looks ok to me, can I re-use it?
DougQ
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
What brand and model number pump? I usually get seals from the same local supplier as the bearings? Yes the impeller will probably still be good. See if there is any damage to the eye or hub of the impeller. If not, it will still work.
