Gerber Tank to Bowl gasket
Discussion in 'Toilet Forum discussions' started by TonyBagadonutz, Feb 9, 2008.
  1. TonyBagadonutz
    TonyBagadonutz Electrician
    Mar 24, 2005
    Electrician
    NJ
    I have toilet that leaks. :D
    After replacing virtually everything not made of china/porcelain, I discovered that the bowl-to-tank gasket(BTG) I installed might be a bit to short :confused:
    The BTG installed was 1 1/8", apparently Gerber's need a different product....
    .....ok.....so....how thick?:rolleyes:
    Navigating the Gerber site was like hiking at midnight with no moon...I discovered the above using Google.
    Searching google again, the thickest BTG I found weighed in at a whooping 1 3/16"!
    Is that 1/16" going to solve all my toilet issues?
    This toilet has a stamp of Feb. 1987 in the tank....and a Gerber sticker still on the side exterior:cool:
    Any help will be appreciated.
    TIA!
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I would check a real plumbing supply house. It does make a difference sometimes. If you installed the tank to bowl bolts wrong it will leak also. If the bolts are not tight enough it will leak. I would double check to make sure that is the problem before you go and get anything else.
    I would toss that toilet in the trash. It is old and should be upgraded to a nice new 1.6 gallon. The money you spend will pay for its self from water saved.
  4. TonyBagadonutz
    Mar 24, 2005
    Electrician
    NJ
    No doubt.
    Imagine my surprise when I stumbled across a PSH that was OPEN on a Sunday at 2:30PM :D
    Community Plumbing Supply Co, Springfield NJ 07081 ...
    At first, I thought it was the bolts - but no water leaked from those areas.
    At one point, the water actually shot the back of the bowl/tank area:mad:
    I would....but....this bath is going to demoed in a few months....just need a quick fix until I can toss it all away and drop a Toto in there ! (TY Terry :) )
    Thanks Patrick.
  5. Kirk
    Kirk New Member
    May 27, 2012
    Texas
    What Model Is My Gerber Toilet
    I have a Gerber toilet that I need to replace find the correct tank to bowl gasket, but I can't tell what model I have. The only marking I can find is on the inside of the tank. The letter A and the date 1982. Any help would be appreciated.
  6. Terry
    Aug 17, 2004
    Gerber does make a thicker tank to bowl gasket. In hardware stores they are packaged for Gerbers.
    This is for the gravity tanks that use the 2" flush valve.
    The Fluidmaster replacements are too thin.
Similar Threads: Gerber Tank
Toilet Forum discussions Gerber tank modification Oct 14, 2016
Toilet Forum discussions Gerber Maxwell 21-418 - any good? bowl: 21-728 tank: 28-490 Oct 25, 2013
Toilet Forum discussions 2nd Gerber Viper with problems? Tank to bowl wont mate level...... Jan 18, 2010
Toilet Forum discussions Will Gerber tank 28-590 fit Gerber bowl 21-660? Mar 11, 2008
Toilet Forum discussions Gerber HE-21-872 toilet with pictures Aug 6, 2016
