Gas line question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by goofy_american, Sep 22, 2008.
  1. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    The B&D chart referred to soft copper Type L for flaring.
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    For my own knowledge, why can't Type L be flared?
    HAHA
  3. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It can if you anneal it first... LOL
  4. Terry
    Aug 17, 2004
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Those are absolutly horrifying photos. Thanks for posting them. Unfortunatly I doubt the point will be taken. When certain guys get something in their heads, nothing is going to stop them. I often wonder how many of these guys let their wives see the thread? Bet they'd be making a call to a licensed pro if the old lady got wind of things.:D
    On the type L copper thing. I have seen it listed also but never in 35 years seen it in production. I placed a call to Revear today but have not heard back from them.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    That first link Terry posted where the Kentucky couple was killed in the gas explosion...
    Pretty much sums it up in these quotes...
    I still remember vividly the first gas explosion that I responded to as a volunteer firefighter... All the windows and doors were laying about 30' away from the home in the yard. The casings and all had blown right off the house. The house had a disheveled look to it like it had been picked up off the foundation and dropped slightly cocked on the foundation. The house was on fire.:eek:
    The homeowner who had gone down into the basement through the outside hatch to relight the pilot on a malfunctioning water heater was burned and had ringing ears. He had flipped on a light switch and next thing he knew he was sitting on his butt out in the yard about 50' away.:eek:
    The wife was knocked to the floor when it rapidly came up off the foundation. She also had ringing ears and some minor burns singed hair and so on. She escaped to the outside.
    Due to the severe structural damage to the house our firefighting efforts were from the exterior of the house. Orders were given not to enter the home. After the fire was extinguished and everything was under control we looked around a bit and discovered a pan that was crushed between the house and the foundation when the house came back down. Using this evidence it was obvious that the entire house had lifted off the foundation at least 1' high. The house was later demolished without anyone being allowed to enter the home. Their new home does not have gas!
    Yea! Go ahead! Do your own gas work!
    [​IMG]
  7. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    All I can say is...
    Get Back! cuz she's gonna blow!
    DIY Homeowner that doesn't have the know.
  8. Ladiesman271
    Ladiesman271 Homeowner
    Aug 22, 2008
    Care and maintenance of transformers
    The results shown in those photos were not caused by DIY projects. That being said, if I were going to do that fireplace work myself I would use black steel pipe for the job. A would also at least get a price from a pro to do that job. If it was a propane job, I would not do it myself.
    I repiped my gas line to my instantaneous water heater with black pipe (about 10 feet of pipe). It is not hard to do, but it takes a lot longer to plan the work than most people realize. I also changed the shutoff valve to my furnace while I was at it.
    Still, you need to know what you are doing for DIY gas / vent work. The national fuel gas code book is an excellent resource. If you can not understand the code book, you should not DIY!
  9. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    There is a misunderstanding that Propane is more dangerous than Natural gas. They are both equally explosive and dangerous.
    I would also pipe this in steel pipe and so would the vast majority of gas fitters and plumbers. But as you know, steel pipe takes more work and specialty tools where as flaring copper is fairly simple.
    1/2" type L copper is hard tempered. It can not be flared and even if annealed to soften the pipe you would have to use acr fittings to make up the joint as 1/2" nominal L, is 5/8" actual outside diameter and 1/2" soft copper is 1/2".
    On a further note. When it comes to advice about gas piping or gas appliances or for that matter gas anything, I'm done. I'm not going to have anything to do with gas related questions anymore either helpfull or not helpfull or even wize cracks. It has become a painfully obvious that there are too many that are willing to take on a task that could very well injure or kill themselves or their families, with no regard given to the professional who's advice they seek. I have no idea what your abilities or qualifications are and frankly even if you post them I would still be skeptical unless you were able to post a copy of your license. Therefore in my mind it is not ethical for me to either give advice or make criticism of your project in one way or another.
  10. Ladiesman271
    Aug 22, 2008
    Propane and natural gas are a bit different. Propane gas is thinner than air (and settles to low areas generally); whereas, natural gas ( methane) is lighter than air (and rises generally).
    "Generally, approximately 26 million people use propane gas; whereas, more than 100 million people use natural gas. You are four times more likely to be involved in a fire or explosion using Propane (LP Gas) vs Natural Gas (Methane). You are 13 times more likely to be severely injured or burned with Propane (LP Gas) vs. Natural Gas (Methane). You are more than 100 times more likely to be killed or severely injured if there is a product failure using Propane (LP Gas) vs. Natural Gas (Methane)."
    http://www.burnsurvivor.com/injury_examples_gasexplosions.html
    I trust my ability to use and test steel pipe and fittings. I prefer not to use short length flex gas connectors for fixed equipment, let alone long runs of copper lines (as proposed above) and the use of flaring tools and other fittings.
  11. Redwood
    Dec 15, 2007
    Service Plumber
    So another words...
    You're a Gambler!
Similar Threads: line question
Plumbing Forum, Professional & DIY Advice Question on how I've looped the PEX lines Jun 19, 2016
Plumbing Forum, Professional & DIY Advice PEX and gas line questions for laundry room Nov 23, 2015
Plumbing Forum, Professional & DIY Advice New water line questions Oct 27, 2015
Plumbing Forum, Professional & DIY Advice Propane Line and Tank Question Oct 23, 2015
Plumbing Forum, Professional & DIY Advice Sewer Line Lateral Routing Design Question Sep 3, 2015
