Garbage disposal install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mar3232, Jun 8, 2013.
  1. mar3232
    mar3232 Member
    Oct 31, 2011
    Indiana
    Let me guess, you should probably put thread lock on those 3 bolts that tighten the mounting clamp on a disposal. ? I'm not a plumber and installed the disposal about 2 months ago -- thought it sounded noisy and looked down there to see that a couple of these bolts had backed out.
    Of course no where in the instructions did it mention putting a thread lock compound on them.
  2. Terry
    Aug 17, 2004
    More likely the putty squished out and the flange was loose because of that.
    I try to use very little for that reason.
  4. mar3232
    mar3232 Member
    Oct 31, 2011
    Indiana
    Terry, thanks -- I should probably remount it then. I have a feeling I used way too much putty. I think because I don't use it all the time, I think the more the merrier because I honestly can't believe it works compared to something like silicone etc. (which I know you shouldn't use).
    It's not leaking though -- if you think I just tightened it up and did the thread lock I'd be ok? thnaks
  5. Terry
    Aug 17, 2004
    If you snugged it up it should be fine. That will squeeze the extra putty out.
  6. hj
    disposer
    We can't tell why it came loose, but I have never used "LockTite" on the bolts, nor have I ever seen it done. Install the disposer correctly and it will not come loose.
  7. mar3232
    mar3232 Member
    Oct 31, 2011
    Indiana
    I know Terry hit it on the head -- too much putty -- hence, probably making it slide around too much. It was done right, but just that -- too much goo.
  8. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Not to nit pick, but perhaps not done right if too much putty (or maybe more to the point, didn't snug up the 3 bolts adequately at the time of install since that would have forced out the excess putty anyway).
    Not a pro, but have have never used thread lock and have never seen the bolts come loose despite all the vibration a disposer creates.
  9. Terry
    Aug 17, 2004
    When there is too much putty, it can show up later, just the way it was mentioned above. We've all done it at least once.
  10. SteveW
    Feb 11, 2005
    Omaha, NE
    Good to know, Terry. I didn't realize that was possible. I have always erred on the side of using a pretty thick rope of putty, figuring out the excess would get squeezed out (and recycled back into the container).
    Still seems to me that if the flange is angled at all, it wouldn't be possible for excess putty to hang out under the flange?
  11. MichaelBukay
    MichaelBukay Plumber
    Jan 14, 2013
    CA Plumbing Contractor, Working for the man in CO
    Conifer, Colorado
    I have installed hundreds of disposals. I only had one install where the collar came loose. I agree, probably too much putty. I think thread lock is a bad idea overall for that application.
Similar Threads: Garbage disposal
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Help with garbage disposal replacement Dec 26, 2016
Plumbing Forum, Professional & DIY Advice UK running trap for garbage disposal Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Garbage disposal / P-Trap Mismatch Nov 1, 2016
