frozen water meter
maplumber
iam plumbing a 2 bath house in ma and the water meter froze and burst, needs to be replaced. could anyone tell me the first step itake to get a new one. i have to call the town right, or should the homeowner call and set it up themself.
Gary Swart
Yakima, WA
Why don't you call. If the city wants the homeowner to call, then pass the ball to him. It's not like you will get in trouble if it's not your place to make the call.
Cass
If it froze and burst they will be billing you for the replacement...You need to call your water supplier...
meter
The only thing that should have broken is the freeze plate on the bottom. That is inexpensive and they usually replace it as part of their service.
Cass
Not around here...they bill you for it....the last one I knew of was $115.00
Southpaw134
Florida
I work for a city owned utility and we are responsible for everything up to and including the meter. In this case it wouldn't matter who called we would still come replace the meter free of charge.
Call the utility, as a poster indicated above they aren't going throw you in jail for calling.
meter
They don't HAVE to replace the meter, just the cast or plastic bottom, but probably would because it was easier and they can then rehab the old meter.
posts
Because there are two gazillion questions and/or answers that require some expository replies to them. The only thing worse than no answer is a bad one.
