jmoser
Oh no, plugging the bleeder valve means pulling everything up, since I believe it is very close to the pump/motor? Thats a pretty big job for me.Yes it could very well be a bad reset button. Those are not made to be reset very many times. The silver capacitor should be fine. If you have replaced the black capacitor and square black relay, you might as well put on a new reset button. It should only be tripping if the amps are greater than SFA, which I think is 11 something on your pump.
Also, you will need to either plug the bleeder down the well or make sure it is a brass one before switching to a diaphragm style tank and using a Cycle Stop Valve.
I will check with my well company to see if they know what kind of bleeder is installed. If it is not brass, what is the risk?
