jmoser
My well pump is frequently tripping. I hope I am using the right names of the parts as I try to describe this.
When it trips, I find the tank is totally empty, and there is no water running in the house. I can restart the pump by using the reset button on the bottom of the control box.
I noticed there was a humming sound coming from the control box when the pump was running. So I replaced one of the capacitors and the start relay switch. I also replaced the snifter and the pressure switch (where the contacts are). I realize now that I didn't replace the AVC which I removed but I thought it was ok because the float wasnt' broken. I will replace that, but could it be the cause of this problem?
When I press the overload reset button on the bottom of the control box, It resets. The well turns on when I hold the little metal lever on my pressure switch. Initially the tank pressure is zero, and it takes several minutes until the tank pressure reaches over 20# so that I can release the metal lever and the pump will keep filling the tank. after I release the lever the tank continues filling to 50# and stops. When it runs down to 30# the pump kicks on and refills the tank again. I think that is how it is supposed to work. But within days, it was tripping again. Now it is tripping even more frequently.
I emptied the tank when I checked the float on the AVC so it seems like it shouldn't be waterlogged already.(I don't have a bladder tank, its the old fashioned kind). My pump does cycle frequently, always has. We just don't run enough water at a time. We replaced the pump and the bleeder valve (the one about 20' down in the casing) just a few years ago.
So I'm thinking maybe my pump is going bad from so much cycling. Can you tell me how to test the pump? Obviously if its bad I will call the pump company but I'd like to see if I can trouble shoot it myself. I have a voltmeter that I used to test the components in the control box (except for the switch relay which I just replaced and discovered it was the source of the humming sound).
Also, is there anything I can do to keep our pump from cycling so frequently? It is very hard for us to run enough water at a time to run the pump continuously.
The pump is a 1.5HP pump running on 220v. The breaker is a 30amp double pole. The only thing running on the breaker is the well pump. The pump is down about 126' (well deptyh 140', water level 100', last measured in 2010).
