Freezing Tank
Discussion in 'Pumps and Tanks Well Forum & Blog' started by TMountainHigh, Jan 28, 2013.
  1. TMountainHigh
    TMountainHigh New Member
    Jan 28, 2013
    AZ
    I have an above ground 1000 gallon water storage tank. I am having a horrible time preventing it from freezing. I've been using a drop light with a 250watt heat bulb inside the tank. The pipes are lined with heat tape and insulated. I've seen the stock tank de-icer's, floating and submersible heaters. Can these also be used for household water tanks? And which type might you recommend? thank you :)
Similar Threads: Freezing Tank
Pumps and Tanks Well Forum & Blog Hose hookup / prevent freezing Jan 5, 2016
Pumps and Tanks Well Forum & Blog Winterizing ideas to avoid freezing Sep 24, 2013
Pumps and Tanks Well Forum & Blog Pump that can withstand below freezing temperature? Sep 27, 2011
Pumps and Tanks Well Forum & Blog Outdoor sump pump and freezing Aug 20, 2010
Pumps and Tanks Well Forum & Blog well stopped in freezing weather w. Pumptec Jan 10, 2010
