Craig Cannon
Initially, I could not understand why my Kohler toilet was leaking at the base. I have now found that the flange screws were pulling thru the sub floor due to leaking causing the wood to start rotting and therefore not allowing the toilet to stay secure and not move at all.
Long story short, I have removed the tile and the subfloor and will replace, but I have a question about the drain flange. I'm certain this toilet flange has been replaced by a previous owner (or his contractor) and what they did was cut the top of the flange off flush and then put in a 3 inch gasketed insert, dropping the opening to about 2.5 inches.
I'd like to replace the flange with a proper flange that glues to the outside of the 3 inch drain pipe, but I'm not sure how that can be done with this setup. There is only about 1.5 inches between the bottom of original piece and the top of the 90 below. That's not enough room to put in a coupling and a new flange. Is there a way to do this that I'm not seeing, or should I just stay with the insert fitting?
