Found leaking valve I think What next?
Discussion in 'Irrigation / Sprinkler Forum' started by vaman77, Jun 6, 2011.
  1. vaman77
    vaman77 Member
    Jan 1, 2011
    NJ
    AS posted previously one zone runs constantly.Dug lawn from supply line and think I found the correct valve.(If it's leaking I assume water would flowing out of after I remove the solenoid?) I opened the valve and am wondering what exactly am I supposed to be cleaning. I see a white plastic washer. Is there a screen or bonnet down further?
    thanks
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    I will assume you checked to make sure that the manual bleeds were closed and if so the valve will probably have to be replaced. sometimes replacing the diaphram will fix the problem but I have had very little luck doing that.
  4. vaman77
    vaman77 Member
    Jan 1, 2011
    NJ
    Figured it out.Took valve apart and cleaned it. Works great Thanks for your advice
Similar Threads: Found leaking
Irrigation / Sprinkler Forum Carrying Water Away from Foundation Mar 17, 2008
Irrigation / Sprinkler Forum Leaking Watts Backflow Preventer Oct 12, 2015
Irrigation / Sprinkler Forum Leaking sprinklers when system is off Feb 19, 2014
Irrigation / Sprinkler Forum Leaking Febco backflow valve, only when 1 specific zone starts? May 13, 2012
Irrigation / Sprinkler Forum Two problems - controller leaking, underground pvc broken somewhere Apr 20, 2012
