Flushmate vs Pressure Lite vs ...?
tday01
San Francisco, CA
Pressure Assist use case:
I have a unit which is below grade and therefore has a check-valve in the waste line. This regularly gets blocked (every few months or so). Inspecting the check valve during flushing suggests that the source of the problem is that when the toilet is flushed, the flapper only opens a few degrees, allowing paper to become wrapped around. Higher pressure / flow would force the flapper open more fully.
That being said I am a bit confused by the pressure assist options available. Two I have come across are Flushmate and Pressure Lite (e.g. Kohler models K-3505-0 and K-3505-SS-0). Does anyone have an opinion on which would be better given the goal of faster flow?
Many thanks!
WorthFlorida
Solutions
Orlando, Florida
Flush mate can be used with the existing toilet if the existing toilet flush performance is good.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Sloan Flushmate is tried and true. We've got lots of backflow units installed and no customer has had issues.
Mostly always use Clean Check, but Oatey once or twice, but, never needed to increase velocity to this day.
Curious as to what brand of backflow is causing your issue?
tday01
San Francisco, CA
I'm not sure of the brand; it was installed with the building in 1999. The flapper / gate is pretty heavy metal. I could replace it with a plastic model, but that would require leasing with the HOA...
