Flotec 3 wire Model# FP3212-02 - RUN MANUALLY WITH SWITCH
fallenage31
Oahu
Flotec 3-Wire 4in. Submersible Deep Well Pump — 1/2 HP, 1 1/4in., Model# FP3212-02
How would I set up to run the pump manually with a switch? 3 wires from the pump. 2 wires that come up to the surface
WorthFlorida
6th clinical trail chemotherapy 5/15/24
Solutions
Orlando, Florida
This is from the installation manual. The sub motor control box has a start capacitor and or run capacitor that is required. With a manual setup, should the output water line ever gets closed, the pump could burned out. This is also a 230 volt motor so both those wires coming to the surface are both hot. I highly recommend not to by pass the required installation requirements. Too much liability here.
Fitter30
Peace valley missouri
Just wire double pole 20 amp switch across pressure switch L1 to M1, L2 to M2
might want to add a relief valve 80lbs just in case a valve is turned off not to overpressurise the system.
